Point to Polygon distance
1254
10-26-2011 04:31 PM
PaulaMcNamara
I have 2 layers:
  1. Point layer of outlets
  2. polygon layer of outlet catchment area
There is an outlet_ID attribute on both layers.  Several polygons in the catchment layer make up the catchment for one outlet, so there will be several polygons with the same outlet_ID.
The outlet point is not necessarily in the middle of the catchment area.
Is it possible to work out the distance from the outlet point to the farthest edge of the catchment?
thanks
Paula
markdenil
You don't really want a Point To Polygon distance, but a Point To Point distance, with the second point being the polygon vertex furthest removed from the outlet point.
make a loop to cycle through your outlet points. For each:
create layers of (1) just one outlet and (2) just the corresponding catchment polygons.
use the verticies to point tool (needs ArcInfo, I am afraid) to convert the polygon(s) to vertex points
use the near table tool to get the distance (and direction, if you want that too) of all these points from the outlet
select the point in the near table furthest from the outlet to get the greatest distance (and direction) from that outlet.
blow away the layers and point table; then do the next outlet point.
PaulaMcNamara
Thanks Mark, that makes sense.  I have 9.3.1 ArcInfo...phew.
I'll have to get a python wiz to get a loop sorted for me.
Thanks for your help
Paula
