point to line
1259
11-15-2018 06:45 AM
JamesList
Where is the point to line geoprocessing tool?
JoeBorgione
A  single point or a series of points?  If the former, no; you're stuck with the point.  If the latter see How To: Create connection lines between two or more points
That should just about do it....
AdrianWelsh
MVP Honored Contributor
James,
Look under Data Management Tools and then in the Features set. You'll find it in there.
Points To Line—Data Management toolbox | ArcGIS Desktop
DanPatterson_Retired
a search using
point to line  or points to line yields some pretty weird results in the ArcGIS Pro help, however,
"points to line"  throwing quotes around either yields the desired result
without quotes, it is almost line point/points is being treated as a verb rather than a noun
so much for artificial intelligence, sometimes the quotes help, if only we could remember
