Point to Line tool
6442
12
06-03-2016 11:14 AM
MarcSmith-Doiron
Shapefile is not created while using the Point to Line tool.  Not receiving any error, just shapefile is not being saved.
DanPatterson_Retired
Read my post... the last line about not using a hyphen in the file name... did you see what Darren saw? Did you do the steps I suggest to get to this point?
make sure you don't have a point selected prior to running the tool... this might give rise to...
  • Line feature will not be written to the output if they are made up of less than two vertices.
from the help
and it makes a featureclass I believe, so you might want to check your default geodatabase incase it isn't a shapefile but an FC
Points To Line—Help | ArcGIS for Desktop
mikeclawson
So, I am having the same problem. I have a very basic point set, I run the point to line tool, it says it is successful, no output is created. It doesn't matter if I put the output into a geodatabase or into a shape file, none of my file paths have spaces are dashes. I am not sure how to attach my data set.
