change points location inside polygons randomly
2262
5
03-30-2017 01:16 AM
unbee
Hi, I have one points shape file (large number of points) and one polygon shape file, the problem I has: the points located in every single polygon in cluster (all at the same location). the question now, is it possible to randomize the current points location  inside the polygons (each polygon with its associated points)?
JayantaPoddar
How about you Create Random Points with the polygon layer as the Constraining_Feature_Class, and join the attribute table based on the FID/OID values?
Think Location
unbee
Hi, thanks for your answer, but I cant control the number of the random points inside each polygon based on my points layer
JayantaPoddar
Could you explain the requirement with snapshots of the current scenario?
Think Location
JayantaPoddar
You might also like to have a look at Disperse Markers
Think Location
TedKowal
Honored Contributor
Perhaps this may help ...  http://www.arcgis.com/home/item.html?id=9ea3a6c7c4e349aa96d68497605b61bd
Or
Use  the Create Random Points  ArcToolbox Tool   ...  ArcGIS 10.4 >ArcToolbox>Sampling>Create Random Points
