Point Distance 999999 Error
1658
06-22-2013 09:58 AM
NoahHammarlund
I am a fairly new user. I am just trying to get the distance from hospital addresses to other addresses within a certain radius using ArcMap. I did the same thing with another set of addresses and got to the distance output just fine but this time I am getting an error. So far the steps I have gone through are:
  • used geoprocessing to get the x/y coordinates of the addresses.
  • created an xy feature class
  • projected on the geographic NAD83 plane using define projection
  • reprojected using feature/project on a UTM Projected
  • used the point distance tool with same file as input and near with the xy coordinates
The error I get says 999999 after 7 or 8 seconds of running the point distance tool. I cannot find much other helpful information from the message.
I am trying to save the output to the same folder as the table with the xy projection. I saw another thread post suggest creating a new gdb folder and saving the distance output there (link to that post: http://forums.arcgis.com/threads/35050-Point-tot-point-distance-gives-error-message). I tried that and the distance worked without an error, but I cannot seem to find any openable file when I look in that gdb folder in windows explorer but I do see the file in the catalog in ArcMap.
NoahHammarlund
Does anyone have any ideas on the error or on getting the table from the .gdb? I'd be glad to provide any further information. Thank you.
DanielHall_Ballester
Check your file paths or all input/output data.
Do you have any invalid characters such as spaces?
Check all the way back to the root drive letter
i.e. C:\Users\Bob\My Documents
this has a space between "My" and "Documents".  This can sometimes make tools fall over.  Replace all spaces with something else (I use underscores"_")
Or do you have hyphens in the file names? "-"  Again, these will cause problems.
I hope this helps!
Dan
