need to draw a single point
4115
12-18-2014 08:29 AM
MikeHenson
I have a manhole base map, and my surveyor has gone out and found a new one. I have a Northing/Easting for this point. How can I edit my shape file and just input the N,E for this one point? Thanks
AnthonyGiles
Honored Contributor
Mike,
In Arcmap with your layer added. Click the Editor menu on the Editor toolbar and click Start Editing.
Open the Create Features window by clicking Create Features Create Features on the Editor toolbar.
In the Create Features window, click your manhole point feature template. This sets up the editing environment so that you will be creating new point features in the manhole layer.
Right click on the map and select absolute x y (I think F6 also takes you here). Type in your coords to create a new feature
Regards
Anthony
AnthonyGiles
Honored Contributor
Mike,
Regards
Anthony
Zeke
Honored Contributor
Forgot about that one, thanks Anthony.
Zeke
Honored Contributor
Well, the easiest way would be to go to those coordinates on the map and add a point. One of the tools on the Tools toolbar is Go To XY:
There's also the Add XY Coordinates tool. Either way, you'll need the new coordinates in the same coordinate system as your shapefile,
