My python code is not selecting by location?  Help...
1257
09-29-2011 09:15 AM
LindaVasil
Hi all,
I'm trying to write a python code that will select the grid_codes for the adjacent neighbors for a point shapefile. I want this list to be iterative so it will create temporary selections do some processing and update the center cell. I used select by location method, but when I make a list of the Grid_Codes, only the cursor cell value is returned. I get an error -- "Error in getting output". I tried putting a print statement and a getOutput(0) statement in the code, but I'm getting the same error. I'm stumped! Here's my code up to the point where I'm getting an error:
#Import arc geoprocessing module
import arcpy, sys
#Set variable to the point shapefile
shp = sys.argv[1]
#Add LRG_Value to the point shapefile
arcpy.AddField_management(shp, "LRG_Value", "Long")
#Place an update cursor in the point shapefile table
#move to the first record in the table
cur = arcpy.UpdateCursor(shp)
row = cur.next()
GCA_List = []
#Loop through each record in the table
while row:
#Extract Grid Code and Object ID
GCP = row.getValue("Grid_Code") #GCP = Grid Code of Processing Cell
PIP = row.getValue("PointID") #PIP = Point ID of Processing Cell
#Put ObjectID in sequential order
sql = "PointID" + " = " + str(PIP)
arcpy.MakeFeatureLayer_management(shp, "shp_lyr")
#Select the sequential order of Object ID
arcpy.SelectLayerByAttribute_management("shp_lyr", "NEW_SELECTION", sql)
#Select only the Object ID that are surrounding the cursor cell
Adj_Neighbors = arcpy.SelectLayerByLocation_management("shp_lyr", "WITHIN_A_DISTANCE", "shp_lyr", "40")
print Adj_Neighbors
Adj_NeighborsValue = Adj_Neighbors.getOutput(0)
for codes in Adj_Neighbors:
GCA = row.getValue("Grid_Code") #GCA = Grid Codes from adjacent cells
#Put Grid codes in a list
GCA_List.append(GCA)
print GCA_List
Here's the error:
[11.0] ====> This is the Grid_Code of the first cursor point. I need the surrounding cells as well.
File "C:\Python26\ArcGIS10.0\Lib\site-packages\pythonwin\pywin\framework\scriptutils.py", line 325, in RunScript
exec codeObject in __main__.__dict__
File "C:\Users\Flash\Documents\School\CA\CellularAutomata.py", line 43, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\mixins.py", line 866, in __getitem__
return self.getOutput(item)
File "C:\Program Files (x86)\ArcGIS\Desktop10.0\arcpy\arcpy\arcobjects\arcobjects.py", line 919, in getOutput
return convertArcObjectToPythonObject(self._arc_object.GetOutput(*gp_fixargs(args)))
RuntimeError: ResultObject: Error in getting output
I'm not sure what I'm doing wrong. The points are all 30 meters apart so selecting within a distance of 40 meters should be fine. Can anyone give any suggestions?
Thanks for any help,
Linda
MarcNakleh
Hello Linda,
To answer your main question, the following line
is bugging because Adj_Neighbors contains nothing more than "shp_lyr", i.e. the name of your layer. To actually cycle through the values, you'd need to run a Search Cursor through it as you did with your main shape, using either:
for row2 in arcpy.SearchCursor(Adj_Neighbors):
    GCA_List.append(row2.getValue("Grid_Code"))
or Python's list comprehensions,
GCA_List = [r.getValue('ELEVATION') for r in arcpy.SearchCursor('shp_lyr')]
I also don't know how successful you'll be with this approach, if I'm reading your code right. You're creating a layer for each PIP (and so I presume 1 feature per layer), and then you're running that Layer through a Select by Location to find nearby features. For one, the Select by Location can only return a subset of the layer, so either 1 or 0 features. For two, you're comparing a layer to itself: the output will be the layer, as it will always match itself (which is why you can't do a Select By Location of a shape to itself in ArcMap, if I recall.)
What you would need to do is to create two separate shapes (as arcpy doesn't allow multiple independent layers on the same shape, I believe), turn one into a layer based on your PIP, and run a select by location on the other seeing how many of its features are a certain distance from your first layer's 1 feature.
As a function of your needs, Near (for ArcInfo), Closest Feature Difference (for ET_Geowizards) or
some kind of Buffer Analysis might be mroe straightforward.
Also worth mentioning
- Cursors in 9.x need to be manually iterated through, so you would need to have another row = cur.next() inside your loop to cycle through each row
- You seem to only be looking for values (as opposed to modifiying them), so a Search Cursor would be more appropriate. Also, as you seem to be using arcpy, I can add that arcpy module's cursors can be used as iterators, so you could replace:
row = cur.next()
while row:
    row = cur.next()
with one line:
for row in arcpy.SearchCursor(shp):
- MakeFeatureLayer_management actually allows for a where clause, so you could integrate your SelectByAttribute into it, like so:
arcpy.MakeFeatureLayer_management(shp, "shp_lyr", sql)
A bit wordy, but I hope this helps!
Cheers,
LindaVasil
Absolutely this helps.  I'm pretty new to coding so I did not how to get around a shapefile selecting itself part.  I appreciate all the feedback and the clues of how to rewrite.
Thanks very much!
Linda
