Multiple buffer ring Create Variable from parameter ERROR
1630
05-19-2021 05:24 AM
JanFelixDitlev-Simonsen
I have a problem with creating a variable from a parameter on a multiple buffer ring. I don`t understand why..?
DavidPike
MVP Notable Contributor
It looks like you have a previous output set as a parameter, which makes no sense.
Do you have a good sulotion to the problem? 🙂
DavidPike
I'd need more information on what you're attempting to achieve, a full view of the model, how you imagine it should work etc.
LauraMcGurrin
Did you find a solution to this problem?  I am having the same issue.
Laura
