Multi ring buffer failure
2234
11-19-2013 01:44 PM
raimyhaidar
PLEASE help me .
Im a student from Malaysia , working on a project about soil erosion ,
I am having problems with Multiple Ring Buffer tool in ArcGIS 9.3. Not working for me, even for my colleagues. I searched forum, but i still cant find the solution. it failed to execute the multiple ring buffer .(details as in the picture)
(for distance , i input the data as 100,200,300)
ChrisSnyder
Honored Contributor
Don't use the dissolve option... You are running out of RAM.
You might consider running the dissolve tool on the buffer output as a separate step - specifying the Distance field as the dissolve field - assuming the geometry of each distance ring is able to be dissolve separately.
by Anonymous User
Not applicable
Original User: raimy
Thanks a lot for your reply .
do u mean , i need to multi buffer it separately?
1st - buffer with "NONE" dissolve option
2nd - buffer the 'buffered shapefile' with "ALL" dissolve option
is it??
im sorry ,im still beginner .
