Migrate script tool with parameters to ArcGIS Pro
2531
01-05-2021 04:18 PM
Brian_McLeer
MVP Regular Contributor
I have a script from an ArcMap toolbox that updates text elements in the MXD as user input parameters below. I am trying to update this to work in Pro, but I am having trouble finding resources. I have tried updating certain codes in the second snippet below with text in bold.
Original:
import arcpy
mxd = arcpy.mapping.MapDocument("CURRENT")
# Defines Address Element Name
SiteName = arcpy.GetParameterAsText(0).upper()
Address = arcpy.GetParameterAsText(1).upper()
PreplanID = arcpy.GetParameterAsText(2).upper()
CrossStreet = arcpy.GetParameterAsText(3).upper()
Floor = arcpy.GetParameterAsText(4).lower()
# Autopopulate Remaining Text Elements from User Inputs and Cursor search
for elm in arcpy.mapping.ListLayoutElements(mxd,"TEXT_ELEMENT"):
if elm.name == 'SiteName':
elm.text = SiteName
elif elm.name == 'Address':
elm.text = Address
elif elm.name == 'PreplanID':
elm.text = PreplanID
elif elm.name == 'CrossStreet':
elm.text = CrossStreet
elif elm.name == 'Floor':
elm.text = Floor
Failing update:
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
for elm in arcpy.mp.ListLayoutElements(aprx,"TEXT_ELEMENT"):
elm.text = SiteName
elm.text = Address
elm.text = Floor
MarkBryant
Because Pro has multiple layouts, you need to get the layout as well.
Try something like this:
lyt = aprx.listLayouts("your_layout_name")[0]
for elm in lyt.listElements("TEXT_ELEMENT"):
    elm.text = SiteName
     elm.text = Address
Mark.
Robert_LeClair
Esri Esteemed Contributor
I'd recommend you run the  Analyze Tools for Pro GP tool on your script to see what part of the Python script will need to be changed from 2.7 Python to 3.7.x Python.  The GP tool is available in ArcMap and ArcGIS Pro.
MahmoudHegazy
i have the same issues and want to convert the script from arcmap to arcgis pro
import arcpy, os
arcpy.env.overwriteOutput = True
df = arcpy.mapping.ListDataFrames(mxd)[0]
layerName = arcpy.GetParameterAsText(0)
fieldName = arcpy.GetParameterAsText(1)
imgLocation = arcpy.GetParameterAsText(2)
whereList = []
layerFile = arcpy.mapping.Layer(layerName)
layerFile.definitionQuery = ""
print df.name
with arcpy.da.SearchCursor(layerName, fieldName) as cursor:
    for row in cursor:
        for item in row:
            whereList.append(item)
for wl in whereList:
    arcpy.RefreshActiveView()
    mxd.save()
    layerFile.definitionQuery = fieldName + "= '" + wl + "'"
    new_extent = layerFile.getExtent()
    df.extent = new_extent
    df.scale *= 1.5
    for elm in arcpy.mapping.ListLayoutElements(mxd, "TEXT_ELEMENT", "title"):
        if elm.name == "title":
           elm.text = wl
    outFile = os.path.join(imgLocation, wl + ".pdf")
    arcpy.AddMessage(outFile)
    outFile = imgLocation + "\\" + wl + ".pdf"
    arcpy.mapping.ExportToPDF(mxd, outFile, "PAGE_LAYOUT")
del mxd
