merge or append features classes based on a part of their names
1485
01-22-2014 04:44 AM
PaoloPensalfini
Hi everybody!
I've got ONE file geodatabase with about 400 feature classes (FC). Here attached is a part of that .gdb.
I need to merge that features (or better append one feature - 00 - to the other)  that has got the same name except for the "00".
For example:
"_01P11_line" must be merged with "_01P11_line00"
or better
"_01P11_line00" (input) appended to "_01P11_line" (target)
and, after the merging/appending, delete the "00" feature class.
I was thinking to proceed with an iteration in modelbuilder or/and a python script...
could someone help me, please?
Thanks in advance
Paolo
AdamMarinelli
This should work for basic scenarios that follow the same syntax as the feature classes in the screenshot you provided:
import arcpy
#Set workspace of your File Geodatabase
arcpy.env.workspace = r'C:\gisworkspace\WORKSPACE\Forums\AppendDuplicate.gdb'
#List all polyline feature classes
featureClasses = arcpy.ListFeatureClasses("", "Polyline")
#Iterate feature class list
#Find the inputs in list (ending in '00') and append them to their target
for fc in featureClasses:
    if fc[-2:] == '00':
        input = fc
        #Remove last two characters to find the target
        target = fc[:-2]
        arcpy.Append_management(input, target)
        #Uncomment the next line to delete the input feature class
        #arcpy.Delete_management(fc)
print 'Complete'
