measuring distance between lines
782
01-12-2019 08:55 PM
OferMarom
Hello
I am using ArcGis Pro and I need to calculate the width of a street from property line to property line. I have the property lines layer- and I hope I can use it to find the shortest distance between property lines of a street for each segment of the street.
the only extension  I have is the spatial analyst, if needed I can use network analysis too..
thanks for any advice!
DuncanHornby
MVP Notable Contributor
Suggest you amend your question with images to explain the problem as currently it is unclear what you are asking.
