I'm using Locate Feature Along Routes to locate my points on a route all defined as shape layers on same coordinate systems. But it doesn't work. The points won't be located and the generated table is blank.
Locate Features Along Routes—Help | ArcGIS Desktop
as it indicates, how close are the points to the line?
Around 5 meters. But I have played with radius, it didn’t help.
and coordinate systems are the same... which isn't the same as them showing up onscreen in the same place, because of projection-on-the-fly
When crazy things occur using points along a route, here in this thread I mentioned some things I try....
https://community.esri.com/thread/214168-create-route-event-layer-layer-doest-show-up
The most common issues I see when I use the tool:
1. No ESRI recognized ObjectId in the event/overlay layer
2. Projections not the same
3. No valid route layer
4. Screen refresh lag ... some times at a range of specific zoom levels the data will not display or disappears.
Hope some of this helps...
I had the same problem with a point feature I was trying to locate on a route. It sat 100% directly on the route line, but for some reason the search radius had to be set to something insane for it to find the point.
