LAS
9489
23
02-02-2018 03:47 AM
tinigjeo
HI i have point xyz and can make LAS dataset?
tinigjeo
Yes I try but did work ....this file is free or ought pay for work
Sent from my Samsung Galaxy smartphone.
XanderBakker
Esri Esteemed Contributor
Not entirely sure what you mean. Were you able to successfully run the tool and convert your text file into a las file? In case you haven't please share any error message you obtained in the process.
As I mentioned before the txt2las functionality is part of the "free" open-source LGPL part of the software. In case you have any doubt please contact the owner of the software using this email: [email protected].
tinigjeo
I think when convert txt file on Las..
tinigjeo
hi
I will try  to make your example with  other point  but  doesnt work  for  more now i will send my work
please attach folden to understand  what i have done
XanderBakker
Judging from the screenshot you provided, you are able to successfully run the tool and create the LAS file. Do you have any other question?
tinigjeo
Yes look ok but when I do add the folder it's empty so what can I do for more...
XanderBakker
OK, so you run the tool. It ends "successfully", but does not create any output file (so it does not work). To understand what is happening, I would have to get access to the file you are using and see a screenshot of the settings you use in the tool. Start with sharing a screenshot of the tool configuration. By that I mean this screen:
XanderBakker
Hi tini gjeo , can you share the screenshot as requested? And is it possible to share the data itself?
tinigjeo
Ok it possible talk on private email
tinigjeo
Give me your address for more...
