Iterator values start at 1?
11606
23
03-02-2011 07:59 AM
TomBonnot
I have been trying to use an iterate field value tool in my models.  Each iteration I want to use the value in an SQL expression.  But the first value returned from the iterator is always a "1", which is not in my field values at all.  Because there is no 1, the tool using the expression always crashes.  Why does the iterator generically start with 1 and not my first field value?
Tom
ShitijMehta
I tried on 10.5.1 and i still cannot reproduce it. Please can you share your model? Even if it really contains just two tools.
Thanks!
kingsleyallan
I'm having the same issue with ArcGIS Pro
ShitijMehta
  • Anyone still facing this issue?
  • Can anyone share the model?
  • We want to fix the issue if it exists.
Thanks!
LJuliusson
Hi ShitijMehta, Yes, I am still facing this issue. Here is a model that has this issue. You'll need to try it with your data. I would love it if you can fix this issue. I am on ArcGIS Pro 2.6.1.
Lara
