Issues when projecting Flow Direction Raster
2010
05-26-2021 04:27 AM
NealBanerjee
Hello,
Ive noticed that when I try to project a flow direction raster (D8 format) it sometimes changes values of the cells and makes the output flow direction raster not work.  Im keeping same cell size (but switching units).  Im assuming this has something to do when how raster is interpolated (Im using Nearest).  Anyone have idea/suggestion to force values to stay the same?
Thanks
neal
DanPatterson
MVP Esteemed Contributor
@NealBanerjee  have you gone over the documentation on...
Cell Size Projection Method (Environment setting)—ArcGIS Pro | Documentation
How the Cell Size Projection Method environment setting works—ArcGIS Pro | Documentation
It might give you some insight on your choices given your projection
Addendum.
It might be better to produce the flow direction from a projected DEM first
... sort of retired...
NealBanerjee
Ill check it out - thank you Dan!  Ill post if there is an easy change that "fixes" the issue. Definitely usually would produce directly from DEM, but using the NHD High-Resolution datasets which are quite large so thats why was try to extract area I need.  Thanks again
DuncanHornby
MVP Notable Contributor
Another option is to accept the flow direction grid as-is, generate your catchment polygons and project those? Just an idea.
