Is there an easy way to identify missing ID numbers in a field?
2092
12-14-2017 04:06 PM
by Anonymous User
Not applicable
I have an ID number field and some of the numbers are missing. I know I can identify duplicate numbers in a number field, but can I identify missing numbers. There are almost 5000 numbers and to search for them manually is painful. Thanks.
DanPatterson_Retired
You can calculate your own sequential id field, then compare... the expression is seq_count( first_id_in_field)
Do note that geodatabases use 1 as first OBJECTID
cnt = 0  # ---- change to 1 if using a geodatabase, 0 for shapefile
def seq_count(val):
    global cnt
    if cnt >= val :
        cnt += 1
    return cnt
# __esri_field_calculator_splitter__
seq_count(0)  # ----- change to 1 if using a geodatabase‍‍‍‍‍‍‍‍‍‍
You can then query where the OBJECTID or FID isn't equal to the result you calculate. The big problem is that as soon as it hits a difference then you have to edit it and restart the process.
Another method is to calculate the difference between the previous and current.  The following isn't tested so no guarantees... but I am sure someone will test and fix it
diff = 0
def seq_diff(val):
    global diff
    if val - diff != 1 :
        diff = val
        return -999
    else:
        diff += 1
    return diff
seq_diff(!OBJECTID!)  # ---- or !FID! for shapefiles‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
Try using Python sets to your advantage:
fc = # path to feature class
min_oid, = min(arcpy.da.SearchCursor(fc, "OID@"))
max_oid, = max(arcpy.da.SearchCursor(fc ,"OID@"))
missing_oids = set(range(min_oid, max_oid + 1)) - set(oid for oid, in arcpy.da.SearchCursor(fc,"OID@"))
JoshuaBixby
In terms of performance, the following will be better since it recycles the same cursor instead of recreating cursors:
with arcpy.da.SearchCursor(fc, "OID@") as cur:
    min_oid, = min(cur)
    cur.reset()
    max_oid, = max(cur)
    cur.reset()
    missing_oids = set(range(min_oid, max_oid + 1)) - set(oid for oid, in cur)
