Is there a way to get the maximum value of a column in Field Calculator?
6317
21
04-20-2016 11:37 AM
FrankWakeley
I want to have a function in my model that converts an arbitrary value to a percentage within that column's range. It would need to be dynamic. Right now I have:
def prob( Failure_Score 😞
   my_list = arcpy.da.TableToNumPyArray ("Failure_Score")
   my_max = max(my_list)
   percentage = (Failure_Score / my_max)*100
   return percentage
but it returns nothing. Really any advice would be greatly appreciated.
Attached is a screencap with the two fields in question and the Calculate Field window.
Thanks!
DarrenWiens2
MVP Honored Contributor
Ignoring numpy for the moment, you can load your list via a SearchCursor:
def prob(Failure_Score):
  my_list = [i[0] for i in arcpy.da.SearchCursor('points','failure_sc')] # change to suit your feature class and field name
  percentage = (float(Failure_Score)/my_max)*100
  return percentage
FrankWakeley
Thank you for your reply!
So inputting
  my_list = [i[0] for i in arcpy.da.SearchCursor('PoF_Out','Failure_Score')]
  return percentage
I'm still getting a Null value. Will SearchCursor still work in Field Calculator even though the tool only works horizontally?
DarrenWiens2
Yes, SearchCursor works in the Field Calculator, although it's not very efficient because the function is run for every row in your dataset. So, for every row, the SearchCursor reads every row to load into the list. Likewise for the numpy solution, for every row, the table is transformed into a numpy array.
I think the following sort of pattern may be better, although I'm not 100% sure of the sequence - happy to have someone clarify. I believe the following reads the list once (I switched over to the numpy solution), then refers to the list inside the function:
my_list = arcpy.da.TableToNumPyArray('points','failure_sc')
my_max = max(my_list['failure_sc'])
  global my_max
  return percentage
It's hard to say why you're getting nulls. Are your failure scores numeric?
FrankWakeley
Still no dice 😕
The scores are numeric ranging from 0.001892 all the way to 1788.782401
I'm wondering if I'm inputting a field incorrectly or something of that nature?
DanPatterson_Retired
why don't you include a screen shot of your field and the field calculator side-by-side so people can see... that may clarify your issue
FrankWakeley
Good point. It's updated now.
DarrenWiens2
Here is one way that seems to work in numpy, but I'm not an expert:
  my_list = arcpy.da.TableToNumPyArray('points','failure_sc') # change for your FC and field name
  my_max = max(my_list['failure_sc'])  # change for your field name
  return percentage
WesMiller
Your expression should be prob(!fieldName!)
first, you need to specify the field that you want to use in the field calculation, not the field you want to put it in
second, why don't you use the regular field calculator, with a python parser, with a code block, then enter your code block an put your field calculation in.   The interface you are using is generally only useful if you are using modelbuilder, not fo updating a field in a table.  So examine Darren's code and emulate within the regular field calculator,  when that works, you can copy the code snippet if you do have a need to use that tool in the environment for which it was designed
