how to use create space time cube tool
5374
14
11-21-2016 12:13 PM
Yi-JyunLin
Hi, I am using the "Space Time Cube" tool, and get the below error message. I wonder would anyone know and place help with this problem.
Thanks!
DanPatterson_Retired
stick with STC if you are wanting to go the emerging hotspot route.  It looks like you are working with nominal/categorical attributedata so you will be fine.
Yi-JyunLin
Thank you, Dan.
So should I use the " Select Layer By Attribute tool" to create a proper Date ? I do not see any link you mentioned you sent though.
I moved this thread to https://community.esri.com/community/gis/analysis/geoprocessing?sr=search&searchId=bd43ba59-5d09-44d...‌ ..
Maybe some of the other thread observers could make some suggestions as to a better place or more resources for Yi-Jyun... other the quick demos with perfect data there is little else for users to go by.
Yi-JyunLin
Ok. Thank you !
