How to split GPS data points into different road function class (eg. Interstate, arterial etc.,)
8655
11
09-15-2014 11:26 AM
rohitj
So we have a lot of gps data points for a test vehicle which needs to be analyzed. My attribute table has a lot of columns like vehicle speed, acceleration etc., I have added XY dataset and all the points are visible and I can represent each of attributes in color codes over a base map. Is there any way to split the data points like when the vehicle was in Interstate, arterial, etc., so that I can do some statistical analysis on that split data.
DanPatterson_Retired
That is because you aren't using a shapefile residing in a folder...what it was tested on and designed to work with
rohitj
Thank you again. Its working flawless..
