How to find porperties (polygons) with points (centroid)
913
03-22-2013 11:15 AM
JoseSanchez
Hi all,
I run a process to remove some centroid for a property layer. How can I check if the polygon property layer has now a entroid or if it is missing?
How can it be done with model builder?
thanks
MatthewPayne
Jose,
Are your centroids just another layer in the map?  You could do a select by location to select all polygons that have a centroid using the intersect method.  If the process is more complex than this, please let us know.
Matt
