How can I control the order in which model builder processes are conducted?
6220
6
03-31-2017 09:39 AM
JoshWhite
Honored Contributor
I have a number of processes that are related but independent of each other, I would like to force them to go in a particular order as its easier to diagnose issues when looking at logs after the model fails.  For instance, I have found that my services tend to lock my SDE after a short period and I would like to run the longest process first in order to make sure it gets done and doesn't have to be rerun if locks develop during the model run.
The one at the bottom should run first since it is so long.  I know rearranging the graphic wont help a bit.  The top four processes are much quicker and should be run after the long one.
Josh White, AICP
Principal Planner
City of Arkansas City
AbdullahAnter
Honored Contributor
You need to precondition connect . connect from result (output) of the first processes to the second processes. as in the picture:
JoshWhite
Honored Contributor
Does the output before the precondition affect the input of the next operation though?  They are all separate feature classes, just a bunch of copy feature processes that have to be done pretty regularly and its just easier to use a model.   If this works, I can actually combine two models into one.
Josh White, AICP
Principal Planner
AbdullahAnter
Honored Contributor
Precondition connect is for order processes, first , second ,third ,,.etc.. the only affect of this connect that if the first processes before precondition connect failed, All processes after the connect willl not start and the model will stop.
JoshWhite
Honored Contributor
Ok, I still have issues with locking and would like to just stop all services in order to clear locks but I can't seem to make a script a precondition.
Josh White, AICP
Principal Planner
AbdullahAnter
Honored Contributor
locking what?
JoshWhite
Honored Contributor
My services lock my SDE so fast I can't run this long of a model but I think combining the models doesn't work.  Some additional background:  I am trying to copy features from a feature service layer into my SDE and it is such a headache.  This is the only way the county will give me the parcel information.  I'm trying to make this as simple as possible but building the model is proving very troublesome.  I have issues somewhere everytime I run it.
Josh White, AICP
Principal Planner
