hi!!! all I have a multiple point data with attributes falling inside single polygon , i wish to merge the attribute table of all points data with the polygon table without creating duplicate polygons.i am unable to use spatial join as this leads to creat
1695
09-20-2016 04:00 AM
TanmayNaik
i want to use Arc GIS 10.3 for the same any tools or program which i could use to add point table data to the polygon enclosing the points.
I have a multiple point data with attributes falling inside single polygon , i wish to merge the attribute table of all points data with the polygon table without creating duplicate polygons.i am unable to use spatial join as this leads to creation of multiple polygons,
NeilAyres
You probably need to show us the data and exactly what you want to do. What do you mean "merge" all the point data attributes? How to merge? add them up? count them?
JoeBorgione
I'm with Neil on this one; a little clarification will go a long way.  Seems to me if all your points are in the same polygon, half the job is already done...
