Hello!
I am trying to successfully return a feature layer as the output of the GP service and having absolutely no luck.
I have a very simple python toolbox tool with the following output parameter:
out_features = arcpy.Parameter(
displayName="Output Features",
name="out_features",
datatype="GPFeatureRecordSetLayer",
parameterType="Derived",
direction="Output")
return [out_features]
The main code block looks like this:
def execute(self, parameters, messages):
"""The source code of the tool."""
inFeatures = r"D:\Projects\OCTA\LODES\data\Test_GP_Service\Test_GP_Service.gdb\Parcels_SaltLakeSub"
out_fc = arcpy.CreateScratchName("out_features",
data_type="FeatureClass",
workspace=arcpy.env.scratchGDB)
out_fc = arcpy.analysis.Buffer(inFeatures, out_fc, 100).getOutput(0)
arcpy.AddMessage(out_fc)
#parameters[0].value = out_fc
arcpy.SetParameter(0, out_fc)
return
I'm able to execute the tool successfully and publish the results to a standalone ArcGIS Server.
When I submit the job, the logs say that everything was executed successfully and the feature class in scratch.gdb in the related arcgisjobs folder looks correct on the server.
However, when I try and view the contents of the output either using the REST endpoint by submitting a job using Javascript, it is always empty.
Somehow, I'm not setting up the output parameter correctly but I can't figure out the trick.
Any ideas are greatly appreciated.
Thank you!
Jill
In case it's helpful to someone else, changing the output parameter type to "DEFeatureClass" did the trick.
datatype="DEFeatureClass",
direction="Output")
direction="Output")
