Geoprocessing : rectify
2769
7
03-08-2012 05:05 AM
Marc-AndréRobin
I imported a jpg. and I added control points using the georeferencing tool.
After that I click update georeferencing. Then I wanted to rectify my raster to create a new one.
When the rectify window open the format is lock on File geodatabase so I cannot create a new raster.
I don't know why it's not working because I have rectify a lot of raster image before that.
Thanks for the help
Marc
TimothyHales
Esri Notable Contributor
You need to change the output workspace.  It defaults to a File Geodatabase; therefore, the output would be a File Geodatabase raster.  Change this to a folder, and then you can output to a different format.
TimothyHales
Marc-AndréRobin
Thanks a lot for the help
MarkSmitheram
I have had the exact same issue but next is how to change it
any pointers as its starting to do my head in and I bet it will be so simple to do
TimothyHales
To change the format you need to change the output location to a folder instead of a File Geodatabase.  Once a folder is selected, you can change the format from the drop down.
mohammedalharthi
thales007
can you show me how can i Change the workspace to a file folder plz ??
TimothyHales
Please see the screenshot in the above post.  Click the folder button from the dialog, and browse to and select the folder.
mohammedalharthi
thank you very very much 🙂
