Generate Near Table
5730
04-20-2015 05:52 PM
StanaforthHopkins
Tries to generate a near table for a point shapefile to a polyline shapefile as shown in the picture. No near points or distances are returned - the table is empty. Any ideas? Running 10.3.
Tags (1)
SepheFox
Are you trying to get the distance to the selected feature shown in your screenshot? Is it definitely closer than the 1000 meter search radius you specified? What happens if you leave the search radius off?
StanaforthHopkins
Yes, yes, and the same thing.
BlakeTerhune
Try switching the inputs, so the near features are the points and the input features are the shorelines.
DanPatterson_Retired
And the two files are in the same coordinate system? (not going by visual due to projection-on-the-fly...and I noticed the word latitude in the first image and you are using planar method)
