Finding landslide initiation points
1238
12-10-2013 06:21 AM
ThomasStanley
New Contributor III
I would like to know if there is a simple geoprocessing sequence to get landslide initiation points from these layers:
  • SRTM DEM (90m)
  • Landslide polygons (many different sizes and shapes)
(Initiation points are typically near the top of the slope portrayed by these polygons.)
I think that there might be a creative solution (like reversing the elevation and then using raster hydrology tools), but I am not familiar enough with ArcHydro to see what it is.
I have already considered these methods:
A geologist examines each of over 24k polygons and digitizes the initiation points individually.
This is the right way to do it, but too expensive.
Write a python script from scratch that does this.
Sounds like fun, but I don't have the time.
Use zonal statistics.
This seems like it would be the right answer, but it has 2 problems:
The raster resolution is so coarse that some small landslides may be lumped with big ones.
[ATTACH=CONFIG]29723[/ATTACH]
Some polygons have multiple initiation points.
[ATTACH=CONFIG]29724[/ATTACH]
ThomasStanley
New Contributor III
Ended up using zonal statistics for this. The 1st concern I had may be addressed by judicious use of the the priority setting.
However, I had to accept that multiple initiation points would not be retrieved from the same polygon (unless they had exactly the same elevation).
