Solved! Go to Solution.
I finally got that to work. There was some issue with model which got resolved.
I have one question. In case of the curves or sharp turns, the resulting segments are not consistent. I understand this is because we are drawing lines perpendicular to pipeline so this is expected to happen in case of curves/sharp turns.
Is there a way we can recitfy this. I have attached a screenshot of my output. Please take a look.
Currently I am talking to the actual user of this tool and then I'll get confirmation if they are flexible in this scenario. The initial requirement was to keep the distance along pipeline same i.e. 1 Km. However the lines cutting other lines are unwanted and we need to correct them. How do we go about it?
Thank you Richard, for your kind help. Really appreciate it. I will try this method.
