Final Geoprocessing output parameter is not generating Url  to download the file.
1896
02-26-2024 11:10 PM
MohammedAbdul
The model tool is created and Geoprocessing service is published.
The final out put of tool is File geodatabase .gdb and downloads on browser
Kindly assist the final output parameter is not generating Url  to download the file.
ArcMap8.1,ArcGis enterprise 10.8.1
MohammedAbdul
I resolved myself as below ,Just incase it can be helpful to anyone
import arcgisscripting
import arcpy
import os
import sys
import traceback
import zipfile
import re
import shutil
gp = arcgisscripting.create(9.3)
class LicenseError(Exception):
    pass
def setUpCoordSystemEnvironment(coordinateSystem, customCoordSystemFolder):
    # get the correct spatial reference and set it into the environment
    # so that the data will get projected when clip runs
    # if it is a number, assume we have a WKID and set it directly in
    # else, find the file in the Coordinate System directory
    if coordinateSystem.lower() == "same as input" or coordinateSystem == "":
        return "same as input"
    if coordinateSystem.strip().isalnum() and customCoordSystemFolder == "":
        try:
            gp.OutputCoordinateSystem = coordinateSystem.strip()
        except:
            #Message "Coordinate System WKID %s is not valid.  Output Coordinate System will be the same as the input layer's Coordinate System"
            gp.AddWarning(get_ID_message(86131) % (coordinateSystem))
            coordinateSystem = "same as input"
            gp.OutputCoordinateSystem = None
            pass
        return coordinateSystem
    found = False
    # Search custom folder if specified
    if customCoordSystemFolder != "":
        found, coordinateSystemPath = getPRJFile(coordinateSystem, customCoordSystemFolder)
    # Search to see if we can find the spatial reference
    if not found:
        srList = gp.ListSpatialReferences("*/%s" % coordinateSystem)
        if srList:
            coordinateSystemPath = os.path.join(os.path.join(gp.getinstallinfo()["InstallDir"], "Coordinate Systems"), srList[0]) + ".prj"
            found = True
    if found:
        gp.OutputCoordinateSystem = arcpy.SpatialReference(coordinateSystemPath).factoryCode
        return coordinateSystemPath
    else:
        #Message "Couldn't find the specified projection file %s.  Output Coordinate System will be the same as the input layer's Coordinate System."
        gp.AddWarning(get_ID_message(86132) % coordinateSystem)
def getPRJFile(inputCoordSysString, prjDir):
    inputCoordSysString += ".prj"
    # walk through the dirs to find the prj file
    if os.path.exists(prjDir):
        for x in os.walk(prjDir):
            if inputCoordSysString in x[2]:
                return True, os.path.join(x[0], inputCoordSysString)
    else:
        return False, ""
    # if we got to here then it didn't find the prj file
    return False, ""
def zipUpFolder(folder, outZipFile):
    # zip the data
    try:
        zip = zipfile.ZipFile(outZipFile, 'w', zipfile.ZIP_DEFLATED)
        zipws(folder, zip, "CONTENTS_ONLY")
        zip.close()
    except RuntimeError:
        # Delete zip file if exists
        if os.path.exists(outZipFile):
            os.unlink(outZipFile)
        zip = zipfile.ZipFile(outZipFile, 'w', zipfile.ZIP_STORED)
        zipws(unicode(folder), zip, "CONTENTS_ONLY")
        zip.close()
        #Message"  Unable to compress zip file contents."
        gp.AddWarning(get_ID_message(86133))
def zipws(path, zip, keep):
    path = os.path.normpath(path)
    # os.walk visits every subdirectory, returning a 3-tuple
    #  of directory name, subdirectories in it, and filenames
    #  in it.
    for (dirpath, dirnames, filenames) in os.walk(path):
        # Iterate over every filename
        for file in filenames:
            # Ignore .lock files
            if not file.endswith('.lock'):
                #gp.AddMessage("Adding %s..." % os.path.join(path, dirpath, file))
                try:
                    if keep:
                        zip.write(os.path.join(dirpath, file),
                        os.path.join(os.path.basename(path), os.path.join(dirpath, file)[len(path)+len(os.sep):]))
                    else:
                        os.path.join(dirpath[len(path):], file))
                except Exception as e:
                    #Message "    Error adding %s: %s"
                    gp.AddWarning(get_ID_message(86134) % (file, e[0]))
    return None
def createFolderInScratch(folderName):
    # create the folders necessary for the job
    folderPath = gp.CreateUniqueName(folderName, gp.scratchworkspace)
    gp.CreateFolder_management(gp.scratchworkspace, os.path.basename(folderPath))
    return folderPath
def getTempLocationPath(folderPath, format):
    # make sure there is a location to write to for gdb and mdb
    if format == "mdb":
        MDBPath = os.path.join(folderPath, "data.mdb")
        if not gp.exists(MDBPath):
            gp.CreatePersonalGDB_management(folderPath, "data")
        return MDBPath
    elif format == "gdb":
        GDBPath = os.path.join(folderPath, "data.gdb")
        if not gp.exists(GDBPath):
            gp.CreateFileGDB_management(folderPath, "data")
        return GDBPath
    else:
        return folderPath
def get_ID_message(ID):
    return re.sub("%1|%2", "%s", gp.GetIDMessage(ID))
if __name__ == '__main__':
    try:
        zipFolder, scratchFolder = None, None
        # Get the Parameters
        zipFolder = gp.getparameterastext(0)
        #inputGDBFolder = gp.getparameterastext(6)
        outputZipFile = gp.getparameterastext(1).replace("\\",os.sep)
        zipUpFolder(zipFolder, outputZipFile)
    except:
        e = sys.exc_info()[1]
        arcpy.AddError(e.args[0])
        sys.exit(1)
    finally:
        if zipFolder:
            shutil.rmtree(zipFolder, ignore_errors=True)
        if scratchFolder:
            shutil.rmtree(scratchFolder, ignore_errors=True)
AlexanderDanielPratama
Have you create an output in the scratch environment? %scatchGDB%  for gdb or %scatchFolder% for folder
Solved: Scratch GDB in Modelbuilder - Esri Community
Either shp file or gdb you need to put it in the scratch environment
Hope it helps you
Cheers
MohammedAbdul
Thanks for your support.it is updated with scratchGDB workspace env , still output url is not generated in map service as shown below
Kindly suggest
MohammedAbdul
import arcpy
import os
import sys
import traceback
import zipfile
import re
import shutil
    pass
        try:
        except:
            pass
    found = False
    if not found:
        if srList:
            found = True
    if found:
    else:
    else:
        return False, ""
    return False, ""
    # zip the data
    try:
        zip.close()
        zip.close()
    #  in it.
                try:
                    if keep:
                    else:
    return None
    return folderPath
    if format == "mdb":
        return MDBPath
        return GDBPath
    else:
        return folderPath
    try:
    except:
        sys.exit(1)
    finally:
        if zipFolder:
        if scratchFolder:
