Fill the space between polygon features?
14526
7
09-12-2012 02:53 PM
DylanLinet
[ATTACH=CONFIG]17641[/ATTACH]
Edit: I am working in model builder and am looking for an automated or scripted solution!
Thank you!
markdenil
Interactively?
Use the Auto Complete Polygon Tool
It will create polygons in the spaces as you draw a line to close off the opening(s)
If you have a 'hole' in a polygon (no opening to the universe), just draw the line straight across the open space
This will give you two new polygons nested in the space
For the open 'bays' and gaps between polys, set the snapping environment and overshoot a tail into the existing polygon, too.
If you have to close off more than one opening, you can wander the line through an existing poly to get from one opening to another.
Afterwards, you can Merge the resulting polygons, should you so desire.
DylanLinet
Interactively?
I'm sorry I should have provided a bit more detail, I am working in model builder and need an automated tool, or bit of python script to perform this function!
DuncanHornby
MVP Notable Contributor
There is a geo-processing tool that does this (but only if you have ArcInfo license) its called Aggregate Polygons (Cartography toolbox).
Duncan
markdenil
Yes, but even AggregatePolygons_cartography
does not do everything dinet1020 wants
quote:
There will be no self-aggregation, meaning no aggregation within an input polygon feature itself along its boundary
unquote
so the jogs and bays don't get closed.
There IS, however, the old Arc/Info era way of doing it:
Take the group of polygons you want to aggregate, and buffer them outwards more than half the distance you want to close.
Take the buffered polygons, and buffer them negative twice that distance  ((distance * 2) * -1)
Now buffer the second set of buffered polygons outward the original distance.
Generalization: Quick and Dirty!
This will also smooth out any long spidery extensions the original polygons may have had, so make sure it accomplishes what you want, and not something you don't.
Be careful also of collisions and aggregations with other nearby features you would rather keep separate.
DylanLinet
unquote
Ah this is an excellent idea!
I will give this a shot and see if it works.
DylanLinet
unquote
I tried it and that solution worked very well. The only problem was I lost some general sharpness around feature corners. I ended up using "Aggregate Polygons" in the ET GeoWizards tool set which solved the problem perfectly when combined with the buffer tactic. Thanks again for the help!
curtvprice
You can run these three tools in succession to fill any (void) holes in a polygon:'
  • FeatureToLine_management(in, tmp1, "", "NO_ATTRIBUTES")
  • FeatureToPolygon_management(tmp1, tmp2)
  • Dissolve_management(tmp2, out)
