Extract Multivalues to Points, strange error in Python
709
11-19-2011 12:45 PM
DavidHon
I have been working on a terrestrial invasive plant species predictive model in Python for Eau Claire County, WI. I have a bunch of rasters that are controls on the invasive species distributions and intensities, so I join the raster cell data to the invasive species points, and use that information to create a new predictive layer.
However, when I run the model, it displays a strange error, and tells me the input point feature class (the invasive species) don't exist:
"ERROR 000865: Input point features: 'E:\invasive project\analysis\analysis_3.gdb\cs' does not exist."
Any ideas? Here is the code.
import arcpy
from arcpy import env
from arcpy.sa import *
import sys, os
import arcgisscripting
gp = arcgisscripting.create(9.3)
invasives = arcpy.GetParameterAsText (0) #invasive species fcs;multivalue
dfc = arcpy.GetParameterAsText (1)
dff = arcpy.GetParameterAsText (2)
dfr = arcpy.GetParameterAsText (3)
DI =  arcpy.GetParameterAsText (4)
asp = arcpy.GetParameterAsText (5)
slp =  arcpy.GetParameterAsText (6)
rdn = arcpy.GetParameterAsText (7)
rlu =  arcpy.GetParameterAsText (8)
#inraster1-8 are the factors used for reclassing
out_ws = arcpy.GetParameterAsText (9) #output workspace
scratch_ws = arcpy.GetParameterAsText (10) #scratch workspace
stat_rasters = [dfc, dff, dfr, asp, slp, rdn]
rc_rasters = [dfc, dff, dfr, slp, rdn]
gp.addmessage("building raster statistics...")
for stat_raster in stat_rasters:
arcpy.BatchCalculateStatistics_management(stat_raster)
gp.addmessage("...raster statistics complete.")
gp.addmessage("slicing rasters to 50 equal classes...")
for rc_raster in rc_rasters:
sliced_rasters = arcpy.Slice_3d(rc_raster, rc_raster + "_slice", "50", "EQUAL_INTERVAL")
gp.addmessage("...slicing complete.")
all_rasters = [sliced_rasters, DI, rlu, asp]
invasives = invasives.split(";")
for invasive in invasives:
(filePath, fileName) = os.path.split(invasive)
dotInd = fileName.find(".") #finds the extension name e.g. .shp
if dotInd <> -1: #looks at what is before the extension name
  newFC = fileName[0:dotInd] #declares the filename that is before the extension filename
  out_inv = newFC + "_" #adds "_" to the new features' filename
else:
  out_inv = fileName + "_"
arcpy.CheckOutExtension("Spatial")
gp.addmessage("extracting raster values to invasive species points...this will take a while.")
extract_invasive = ExtractMultiValuesToPoints(invasive, all_rasters) #this is the line with the error
gp.addmessage("extraction complete!")
I really appreciate the time anyone has to helping me troubleshoot this.
Thank you!
DH
