Export Selected Attachments ArcGIS Pro
872
04-20-2021 06:18 AM
by Anonymous User
Not applicable
I know of this Article and how to export the entire set of photos, but I want to export selected photos not all since there are over 200k
I am unsure of how to edit the script provided and adjust the parameters so that the Attachment layer can have a selection type and an SQL expression so only the identified files are saved.
DrVSSKiran
I have not sure, whether you tried or not. Before exporting the attachments, first, perform the query option (Using select by attribute)  and select the layers, without deselecting the layer run the tool. Usually, geoprocessing tool by default export the data only selected features.
Regards,
Kiran
by Anonymous User
Not applicable
Thanks for the response.  Sadly it does not work in this situation for whatever reason (I am guessing it has something to do with the script).
