Error Inspector in Topology Tool
3761
03-06-2012 06:45 PM
KaiChum
Hi everyone,
I have an urgent question about the error inspector in topology tool.
Is there a way that to EXPORT the error inspector table?
http://help.arcgis.com/en/arcgisdesk...00000sr000000/
It shows the error as a table but there is no way/option to export it as a table.
I am also trying to write the python script to see if it works.
TimHopper
Kai,
At version 10.0 this is not possible.  The only export options that you have are to export a list of the total amount of errors / type via ArcCatalog.
ArcCatalog > Topology Properties > Errors Tab > Generate Summary
However, in the upcoming release of 10.1 there is a new GP tool which will do exactly this.  Actually, it outputs to a feature class, but if you wanted only the table you could export the attribute table from there.
Export Topology Errors (Data Management) @ 10.1
With this new GP tool you can also access it via python.
KaiChum
Thanks for your reply. The info is very helpful because it saves a lot of time on looking how to extract it as a table. Thanks!
