Error HRESULT E_FAIL has been returned from a call to a COM component.
2887
03-29-2013 12:26 PM
ChaitanyaKrishna
I am writing a small code to calculate the minimum distance between a point and a curve using the near tool in ArcGIS . The code  is as follows
Imports ESRI.ArcGIS.Geoprocessor
Imports ESRI.ArcGIS.AnalysisTools
Public Class Form1
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim gp As ESRI.ArcGIS.Geoprocessor.Geoprocessor = New ESRI.ArcGIS.Geoprocessor.Geoprocessor
        Dim neartool As ESRI.ArcGIS.AnalysisTools.Near = New ESRI.ArcGIS.AnalysisTools.Near()
        neartool.in_features = "F:\Rajdeep-Assam\EQ_Source\FaultLine.shp"
        neartool.near_features = "F:\Rajdeep-Assam\EQ_Source\Epicentre_2011.1.1_20.48.shp"
        gp.OverwriteOutput = True
        gp.Execute(neartool, Nothing)
        MessageBox.Show("Done")
    End Sub
End Class
When i run the code , it shows an error at the line gp.Execute(neartool, Nothing)
What are the possible reasons ?
Thanks
DannyDong
Is that because you didn't set up the workspace? I am having the same issue while trying to use a customized tool in my c# code. I think the error means that the code is trying to access some object that is out of bound or can't be found. However it is too generic and doesn't help with debugging. I tried to find the usage and validate messages from the gp tool but with no avail. Anyone got a solution or suggestion on how to trouble shoot? Thanks!
