Enable Attachments disabled after generating match table
376
06-15-2026 06:51 AM
jgideon_grs
I am trying to attach PDF assessment packets to polygon features on a map.
I use the enable attachments geoprocessing tool, this completes successfully. I have also attempted enable attachment through the manage window on the feature service.
I generate the match table via the geoprocessing tool. The attach table and relationship table appear within the geodatabase, this executes successfully.
When I attempt to use the add attachments, I get an error message that attachments aren't enabled. I check the manage window again, and see that enable attachments is unchecked. I also check the catalogue tab and see that the REL table has also disappeared.
I am using Pro 3.7 and have tested with 2 accounts, one AGOL and one Enterprise, both result in the same issue.
Any ideas?
ChrisUnderwood
Hello @jgideon_grs  , this is what I tried with ArcGIS Pro 3.7, but I did not see any problems.
1. I have a Feature Class in a File Geodatabase.
2. I run Enable Attachments on the Feature Class which creates the ATTACH & REL tables.
3. Using Generate Attachment Match Table I create the match table which does contain the correct matches.
4. Then I run Add Attachments to add the attachments to the Feature Class as expected.
Are you able to post any alternative steps to reproduce the problem ?
