Dissolving Multiple Features?
1551
11-23-2012 07:08 AM
TomHutchinson
Hi all
Is there a tool or script which can dissolve multiple features?
I have many shape files which are the output of a complex model which I need to dissolve by a Sub Type field. The structure and attribute tables of all the features are identical.
I want to avoid building a model which has many dissolve tools running over and over again like this...
[ATTACH=CONFIG]19495[/ATTACH]
Thanks.
T__WayneWhitley
Honored Contributor
I may be misunderstanding your problem but why can't you simply execute the Dissolve once by a field that is coded by the unique values you want to dissolve by?
DanLee
by Esri Regular Contributor
You can use Iterate Feature Class to loop in one shape file at a time to run the same Dissolve process.
Take a look of the example in this Help topic:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Examples_of_using_iterators_in_ModelBu...
It also explains how to use an inline variable for output names.
