Dissolving lines with opposing direcionality
6430
11
03-23-2012 10:51 AM
TomSomers
When you dissolve arcs using the dissolve tool, does directionality of the arcs come into play. In other words, if two adjacent arcs are not going in the same direction will they not be dissolved.
DanLee
by Esri Regular Contributor
Thanks for the good question. I think the tool could provide an option for additional analysis to preserve existing line direction as long as a set of connected lines are all in the same direction. I will propose the enhancement for a future release. If you like, please submit an enhancement request through Esri Support as well.
geodanadmin
Fix by rebuilding geometry in arcobjects & perform ITopologicalOperator.Simplify. (TODO: set MAware, ZAware, M's and/or Z's)
        private IFeatureClass FixArcGisDoubleLinesBug(IFeatureClass unsplitFeatureClass)
            IFeatureCursor updateFeatureCursor = unsplitFeatureClass.Update(null, false);
            try
                for (IFeature feature = updateFeatureCursor.NextFeature(); feature != null; feature = updateFeatureCursor.NextFeature())
                    IGeometry srcGeometry = feature.ShapeCopy;
                    var srcPointCollection = srcGeometry as IPointCollection;
                    IPath targetPath = new PathClass();
                    var targetPointCollection = targetPath as IPointCollection;
                    object missing = Type.Missing;
                    for (int i = 0; i < srcPointCollection.PointCount; i++)
                        IPoint aPoint = new PointClass();
                        aPoint.X = srcPointCollection.Point.X;
                        aPoint.Y = srcPointCollection.Point.Y;
                        targetPointCollection.AddPoint(aPoint, ref missing, ref missing);
                    IPolyline targetPolyline = new PolylineClass();
                    var targetPolylineGeometries = targetPolyline as IGeometryCollection;
                    targetPolylineGeometries.AddGeometry(targetPath as IGeometry, ref missing, ref missing);
                    ITopologicalOperator topologicalOperator = targetPolyline as ITopologicalOperator;
                    topologicalOperator.Simplify();
                    feature.Shape = targetPolyline;
                    updateFeatureCursor.UpdateFeature(feature);
            finally
                if (updateFeatureCursor != null)
                    Marshal.FinalReleaseComObject(updateFeatureCursor);
