Dissolve in Modelbuilder
1641
10-11-2012 02:06 PM
SteveRichards2
Hello,
I currently have two PC's running arcgis desktop 10.1. It seems the modelbuilder behaves differently when running the Dissolve Tool (Data Management). One PC will "merge" multipart polygons with the same parameters set in the tool. The other PC will not "merge" the polygons leaving them seperate from one another, even though they have the same attributes. Any help wih this would be much appreciated. Thanks in advance.
Steve
SteveRichards2
Nobody has the same problem in ArcGIS Desktop 10.1?
ClintOffutt
Did you ever figure this out?
DanEvans
Could it be something as simple as one PC not having the MULTI_PART option set?
ClintOffutt
No. The tools works fine from arc toolbox. Just not in modelbuilder.
curtvprice
Check your results tab to see if the arguments are the same.
