Then this becomes an issue,.
How does one then iterate through 1000's of dwgs and convert to a GDB.
Iterate Datasets gives a Dataset, but not able to 'connect' to CAD to Geodatabase
Iterate using DataSet type = CAD will not pick up dwgs. this has been a deceiving term used (discussed in other threads).
So how does one cycle through all the dwgs in a folder and use the CAD to Geodatabase Geoprocessor?
Also, to state "Feature Layers do Not support Annotation" doesnt quite make sense to me, am I missing something?
Make Feature Layer works fine when SELECT data / Child Data Element = Annotation is used and is derived from a Geodatabase. I use this in other pyhon scripts.
This works for example,
but how would you iterate this through many dwgs (and another downfall is MODEL will overwrite the Dataset name in a FGD, but running through python, will increment the dataset name. (I dont want 1000's of Datasets in a FDG, all separate) if possible
