Creating wedge-shaped territories
14258
32
01-19-2016 07:02 AM
JuanetteWillis
Good morning, I am trying to create new territories for our inspectors based on the number of locations to be inspected. Our office is centrally located in the county. We are wanting to have wedge-shaped territories radiating from our office, like pieces of a pie. Any suggestions on how to have the GIS assist with the division?
Juanette
WesMiller
Do you have an advanced license? You could put a point at the center of each proposed area then use Create Thiessen Polygons—Help | ArcGIS for Desktop  to create the polys.
JuanetteWillis
Unfortunately no, I do not have an advanced license. Just basic ArcMap 10.1 with the Spatial Analyst extension.
WesMiller
When i did districts for my codes enforcement inspectors i used the Districting for ArcGIS | Overview  the tool is intended for political boundaries but i used five years of historical inspection data to create a balanced set of districts.
JuanetteWillis
I did not know about this add-on. It shows potential. Since this is for inspecting restaurants, hotels, pools etc. I do have a specific set of locations.
XanderBakker
Esri Esteemed Contributor
I haven't tried the tool yet, but Dan Patterson​ published a tool to calculate Thiessen polygons with a Basic license: http://www.arcgis.com/home/item.html?id=6e9bc6cbf93d4939b2eb04ff8519be47
SheldonBaker
Juanette,
Looks like you have some grounds for asking for a GIS upgrade from the County?
JuanetteWillis
LOL Sheldon. I don't think this one time project would justify the expense. But I can dream.
JuanetteWillis
P.S. Sheldon, it is great to see you on here. I worked in Big Bend NP for a while and miss the wide open spaces. I would love to have a private conversation and hear more about your work for NPS.
ChrisDonohue__GISP
Just wanted to toss out a couple of ideas, though it may be more elaborate than you want:
1.  Most of the inspections will likely require transiting a street network.  If points could be established at the center of each "territory" (see the idea by Wes Miller  , then if you have access to the Network Analyst Extension, you could run a Location Allocation to refine the territories.
ArcGIS Help 10.1 - Network Analyst
2.  In terms of figuring out where to place the "center" of each territory, there may possibly be a way to derive those centers using the Geostatsical Analyst Extension.  However, I'm not super-familair with this extension, so we'd need someone who is to chime in here.
ArcGIS Help 10.1
Chris Donohue, GISP
