Creating DEM from contours
6702
07-30-2015 10:39 PM
alexandernongkhlaw
hi
Please help me what are the steps to create a DEM from contours is it best to create topo to raster or its best to create from 3D analyst tool....like create a TIN first..actually i want it to show the terrain,slope etc...can anyone help me with the strps please and whch tool to use..thank you
DanPatterson_Retired
I would go with TopoToRaster, if memory serves, the TIN variant will be more influenced by the close proximity of the points along the contour lines....but of course, you have the data so you can confirm
alexandernongkhlaw
ok thank you...and to get the slope we need to use the tool 3D analyst
right??
ThomasSteudel1
Hi Alexander,
yes its the Spatial Analyst Tool: Surface --> Slope. A Tipp: If you later want to analyse or to calculate using the created DEM and other raster datasets: use a snap raster when creating the Elevation-Raster.
Best regards,
Thomas
alexandernongkhlaw
Thank You....Will try it if i have any problem will definitely get back to
you..
AltinPojani
How can topographic map with contours and hillshade etc...  from digital elevation model
