Creating a query statement
3084
10-17-2014 08:07 AM
joepublic
I would like to display a the result of a query that loops thru an array. The query statement should look the
one shown below:
countryCodes = [840, 332, 643, 724, ....];
for (var i = 0; i < countryCodes.length; i++)
   cntryq.where =     "UN = " + countryCodes =
cntryq.where =     "UN = " + countryCodes = [0] + "OR UN = " + countryCodes = [1] + ....
Is this possible?
My script is attached
KenBuja
MVP Esteemed Contributor
You access objects in an array like
countryCodes
What you should do is build a query like
"UN in (840, 332, 643, 724, ....)"
which is the same as
"UN = 840 OR UN = 332 OR ..."
So you can build the statement this way
var inString = "";
   inString += countryCodes + ", ";
inString.slice(0, -2);
cntryq.where = "UN in (" + inString + ")";
KenBuja
countryCodes
var inString = "";
joepublic
Thanks you Ken!!
Problem solved
