create specified point with python
4974
6
05-10-2010 01:14 AM
alifardy
with python, i want to create point feature class. how to create point in specified coordinate but not from a file which contain coordinate. i have try to make the script but there was an error " 'list' object is not callable. ". anyone have an explanation?
# Process: Add Field...
gp.AddField_management(InputFC__2_, "V", "DOUBLE", "", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
# Process: Calculate Field...
gp.CalculateField_management(InputFC, "V", " * ", "VB", "")
# Process: Summary Statistics...
gp.Statistics_analysis(InputFC__3_, InputFC_Statistics_dbf, "D SUM;V SUM", "")
# create the output feature class using the spatial reference object
gp.CreateFeatureClass(New_Folder,OutputFC,"Point","ENABLED","DISABLED",spatialRef)
gp.AddField_management(OutputFC,"D","DOUBLE","", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
gp.AddField_management(OutputFC__2_,"H","DOUBLE","", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
rows = gp.SearchCursor(InputFC_Statistics_dbf)
row = rows.Next()
while row:
count1 = row.SUM_V
count2 = row.SUM_D
prows = gp.InsertCursor(OutputFC__3_)
# create point object to create feature
pnt = gp.CreateObject("Point")
pnt.id = 1
pnt.x = 566020
pnt.y = 252044
prow = prows.NewRow()
prow.Shape = Point
prow.Dt = count2
prow.H = count1 / count2
Point.Add(pnt)
prows.InsertRow(prow)
row = rows.Next()
del prow, prows
del row, rows
DarshaHardy
What version of ArcGIS are you using (otherwise folks may provide helpful advice you can't implement)?
Could you edit your post to wrap the code in a code tag so the indentation is visible.
Can you step through the code in your code editor to see what line it falls over on?
alifardy
Actually I use Argis 9.3. sorry, i can't edit the indentation in the script, but i mark it with red colour. probably the problem occur in "create feature class" command, or in "insert cursor", this is confusing.
gp.CreateFeatureClass(New_Folder,OutputFC,"Point", "ENABLED","DISABLED",spatialRef)
gp.AddField_management(OutputFC__2_,"H","DOUBLE"," ", "", "", "", "NON_NULLABLE", "NON_REQUIRED", "")
row = rows.Next()
while row:
count1 = row.SUM_V
count2 = row.SUM_D
pnt.id = 1
pnt.x = 566020
pnt.y = 252044
prow.Shape = Point
prow.Dt = count2
Point.Add(pnt)
row = rows.Next()
del prow, prows
del row, rows
DarshaHardy
Are you not able to step though your code in debugging mode to see where your error occurs?
Try breaking things down into smaller pieces, maybe CreateFeatureclass is falling over on something as simple as the a typo in the folder path
GünterDörffel
I wont check through all your code, but there actually is one very prominent error:
you coded:
pnt.id = 1
pnt.x = 566020
pnt.y = 252044
prow.Shape = Point
prow.Dt = count2
Point.Add(pnt)
row = rows.Next()
which wont work, since you assign Point to the shape of the newly added record ... this does not exist!
try:
pnt.id = 1
pnt.x = 566020
pnt.y = 252044
prow.Shape = pnt
here - to continue I'd use:
prow.SetValue("Dt", count2)
prow.SetValue("H" , count1 / count2)
this line here is wrong anyway and obsolete now
Point.Add(pnt)
this should be the correct end of your code:
row = rows.Next()
so altogether this section should read:
pnt.id = 1
pnt.x = 566020
pnt.y = 252044
prow.Shape = pnt
row = rows.Next()
Hope this helps
Regards
Guenter
alifardy
Thanks to Guenter Doerffel, but there is another error with the script, "create feature class" process still didn't work. the error message is:
<class 'arcgisscripting.ExecuteError'>: ERROR 000622: Failed to execute (Create Feature Class). Parameters are not valid.
ERROR 000623: Invalid value type for parameter has_z.
all data type in calculation process is "DOUBLE", and input feature class doesn't has Z values. is the problem in the input file or in script?
DarshaHardy
I think you're missing a value for the (optional) template parameter in CreateFeaturecClass
CreateFeatureClass_management (out_path, out_name, geometry_type, template, has_m, has_z, spatial_reference, config_keyword, spatial_grid_1, spatial_grid_2, spatial_grid_3)
