upslope/downslope along a line
1258
05-03-2010 03:57 AM
ToreBorvik
Hi.
I'm making a model that analyses least cost path From A to B and back from B to A. it outputs a polyline
This line represents a proposed road.
My model has come this far..
Problem: Maximum allowed slope is lesser uphill than downhill, so I need to find a way to add this to the model.
Example: When driving from startpoint A in the west to midpoint B in the east, the road back will likely not be the same as to, since now we drive in the opposite direction and reverse downhill/uphill.
I hope you understand. And I also hope someone has a tip on how to solve it!
Running ArcInfo 9.3.1. with all extensions
ToreBorvik
Thanks for the suggestion. I've tested a bit with path distance but I do not quite know how to get this information from it (I got an output but it makes no sense).
The purpose of my entire model is to add a start point and a stop point and find the quickest way between these while avoiding certain areas (which works fine), but it must also regard the upslope/downslope along the suggested line since the max allowed slope is different between these two.
So the path distance is what I lack. for possible inputs I have pregenerated: DTM raster, slope raster, aspect raster, cost distance raster, cost path line.
And the settings: max 25 degrees downslope  and max 15 degrees upslope.
Can I make the calculation based on what I have? if no, what do I need also? and where do these inputs go into the tool?
ToreBorvik
ahhh. Never mind this whole post. I thought initially that the path distance should be combined with the cost distance. but after trying I see that it can replace the cost distance so that the path distance raster can be input for cost path.
But right now I have two path distance calculations in my model since to my understanding I needed it to calculate both one for FROM A TO B and another one for FROM B TO A.
attached a screen of the model output, seems to work great and I also manually checked it with an aspect and slope raster, does its job 🙂
Blue Line = A to B with certain high cut/low cut angles.
Green Line = B to A with different angles
I could set the angles to be the same and still get different results, but I realized that now I can also model slope restrictions if a forestry truck is either loaded with timber (usually from a to b) or not (b to a). an extra bonus, hooray!
