Count overlapping features
117
6
Monday
CristoforosRomanos
Hello. I have around 250,000 polygons (representing building footprints) to each of which I have applied a 10m buffer (no dissolve). I then use the Count Overlaps tool to investigate how many of these buffers intersect once, twice etc with neighbouring buffers. The results do not appear reliable. In many cases, buffers with 0 overlaps appear to have a count of 1 (overlap). In other cases where there are clearly multiple overlaps the polygons are also counted as 1 with the overlapping area counted as 2. I have checked for duplicate geometry and also separately projected the buffers with dissolve to see if my eyes are deceiving me. I also find that with counts >1 the tool only highlights the (sometimes tiny but important) overlapping area and not the entire overlapping polygons making it difficult to visually pinpoint which buffers are actually intersecting. Moreover, it would be really great if there was a way to count the total number of overlapping polygons (forming a larger cluster) rather than just count the number of overlaps.
Before I plunge into doing this arduous but necessary task manually (by selecting each buffer and then editing a newly created attribute field to match the number of overlaps I can see), I would appreciate any guidance on any of the above.
JonM32
@CristoforosRomanos I see what's going on now!
I tried it on my end and it worked. I did buildings with a buffer and the overlaps were correct. You were right in using the COUNT_ field for symbolizing. The tool counts a single non overlap area as 1. Then, anything over that is an overlap area. So in my screenshot you can see single buildings have no overlap, which have a value of 1. Then 1 overlap area is a value of 2, and so on. test.png
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
JonM32
@CristoforosRomanos
Try symbolizing the overlap layer by the COUNT_FC field, which shows the number of individual feature classes that overlap the feature. It looks like you have the COUNT_ field used, which would show the number of overlapping features in the input.
This documentation explains the tool and output in more detail: Count Overlapping Features (Analysis Tools) | ArcGIS Pro documentation
Cheers,
Jon
CristoforosRomanos
Thanks. The COUNT_FC field has only two classes: 0 and 1. I tried adding more classes from the drop-down in symbology but it only returns those two. Not quite right. Something I am doing (or have already done) wrong?
JonM32
Cheers,
Jon
CristoforosRomanos
Thanks Jon. Your explanation confirms my suspicion. Tool works as advertised. In theory only. 1s should really be 0s if actually counting no. of overlaps. Unfortunately not useful for the task ahead. Ideally would want all polygons with 0 overlaps to be differentiated from polygons with 1s etc. Appreciate the help.
DanPatterson
MVP Esteemed Contributor
Determine the Area of the Overlap between Multiple Polygon Layers in ArcGIS Pro
This document may help explain the output of the tabular results.  The 1 values suggest that there is only 1 featureclass contributing to a particular area and its count_fc is also 1
... sort of retired...
CristoforosRomanos
Thanks Dan. Document does indeed clarify the situation. Seems I will need to do this task manually to achieve the necessary results.
