I am trying to create a shapefile of zip code boundaries using the 2002 tiger/line files available here:
I am relatively inexperienced with GIS, but have come across a few solutions online. The only one that appears specific to ArcGIS is a python script (Basic Tiger Conversion—Help | ArcGIS for Desktop ). However, when I attempt to run the script, I receive a runtime error:
Runtime error
File "<string>", line 1, in <module>
File "c:\program files (x86)\arcgis\desktop10.2\arcpy\arcpy\arc.py", line 1264, in TigerArc
raise e
AttributeError: Object: Tool or environment <TigerArc_arc> not found
I am using ArcMap 10.2.2. Is there an alternative way to convert these files to shapefiles in a straightforward way using ArcMap? I would also be happy to hear suggestions regarding the error I receive, though I am not familiar at all with python.
It requires ArcGIS Advanced with ArcInfo Workstation installed... check the bottom of the help topoic
Thanks for the reply, Dan. My current setup is ArcInfo (advanced, concurrent use). But I guess I don't have ArcInfo Workstation? I am honestly not familiar enough with the various flavors of ESRI products -- I am just using what my university gives me access to.
Is there any alternative route to converting tiger line files?
I would definitely look at the site to see if alternate formats are available.
Has there been any development on this issue? I have been trying to convert some 2000 census TIGER files for Urban Areas with no luck. I am using ArcMap 10.4 and the Basic and Advanced TIGER Conversion tools are available in this version, but I keep getting a generic 999999 error "ERROR 999999: Error executing function. Failed to execute (TigerTool)". The guidance in the ESRI help is very generic and does not provide much in the way of specific examples.
