Complex line to polygon
1290
06-01-2011 07:38 AM
JeremyTibbetts1
I have a complex line, which represents a shoreline.
I am trying to turn this line into a polygon.
What I have been trying is, creating an empty polygon FC.
I enter an edit session, target the empty polygon FC, and select all features from the shoreline FC.
Using the topology tool bar, I click the construct features button, and create new polygons using the selected features into the empty polygon FC.
This has worked before, but using a more simple line. The shoreline FC in this case follows the coastline in more detail, and it seems as the above process does not convert this line as easily.
I was wondering if there is a method for converting a more complex line into a polygon.
thanks,
Jeremy
HardolphWasteneys
Jeremy,
not sure about "Using the topology tool bar, I click the construct features button, and create new polygons using the selected features into the empty polygon FC."
There are at least 3 methods that come to mind for creating a polygon from your shoreline polyline:
1. use the script pair "Write Features to Text File" and "Create Features from Text File" with a simple edit of the text file header from "polyline" to "polygon".  The combo takes the polyline vertices and outputs a new polygon FC with a polygon shape.
2. Use TASK:  Auto-Complete Polygon.
edit a closed single polyline loop out of your shoreline; set up a new polygon FC and make it the Target, change TASK: to Auto-Complete Polygon;
USING THE SKETCH TOOL right click on the polyline; hit "replace feature" (the edit sketch vertices will be shown and the active point will be at the end of a dangle) then hit F2 or right click again and hit "finish".
Outputs a polygon in your target polygon FC.
3. use TASK: Cut Polygon Features.
edit a closed single polyline loop out of your shoreline; create a background polygon in a new FC and set it as TARGET and  TASK: "Cut Polygon Features" and select the polyline with the edit tool;
USING THE SKETCH TOOL right click on the shoreline; hit "Replace Feature"; then F2 or right click again and hit "finish".
Chops a new polygon out of the background one.
The Cut polygon feature method is described in 9.3 Desktop Help; the others not.
anyway check your geometry first in case you have an error.  This is most likely to happen if you had a multitude of convoluted polyline segments and ran the SMOOTH tool on the line which I have seen create self intersecting loops that cause a glitch in these methods.  You can also just run "Repair Geometry" to check if you suspect anything like that.
Hardolph
