Changing NULL values with model builder
3118
05-22-2013 02:58 AM
TanyaEsteves
Hi.
I'm using model builder to build a tool, where at a certain point, I need to take the Z elevation values from the feature class that are NULL and turn them into the value 0 (zero). To do so, I'm using the calculate field tool. I just have a problem... I know very little of VB and NOTHING of python... I was hoping someone could help me create the appropriate code to change the values I need?
I'm guessing it should be something very simple... like an if..then statement? Something like: if Z=Null then Z=0. I just need to "translate" it into programming language.
Any help... please?
Thanks in advance.http://forums.arcgis.com/images/icons/icon7.png
RichardFairhurst
Well, so far I got:
Dim Z
If IsNull () = "True" then
= 0
End if
But it doesn't work... any suggestions?
Thanks.
To do this you need to check the codeblock checkbox.  You also have to handle the situation where the Z field has a value and is not Null.  Finally you cannot use a field name as the output of the calculation only a variable which is only resolved to a specific field by doing the calculation on a given field.
Parser:  VBScript
Prelogic codeblock:
If IsNull() Then   Output = 0 Else   Output =  End If
Expression:  Output
JimCousins
The correct syntax for the NULL keyword is:
"Z" IS NULL
do not use the "=" with NULL.
Regards,
Jim
TanyaEsteves
Well, so far I got:
Dim Z
= 0
End if
Thanks.
RichardFairhurst
Well, so far I got:
Dim Z
= 0
End if
Thanks.
Parser:  VBScript
Prelogic codeblock:
Expression:  Output
TanyaEsteves
Dear rfairhur24,
Thank you so much for your help. It worked perfectly!! I really need to get my head around programming!! http://forums.arcgis.com/images/icons/icon11.png
Best wishes.
