Can I delete content form Default.gdb?
16054
7
02-11-2015 03:25 AM
ayllaBAK
My content in Default.gdb is 30 GB large so it's using to much space on my C drive. Can I delete content, without harming the normal operation of ArcGIS software??
Regards,
aylla@aylla
Tags (1)
XanderBakker
Esri Esteemed Contributor
Yes you can delete the content of the default file geodatabase, ArcGIS will keep functioning correctly. You can even delete the entire file geodatabase and when you start ArcGIS again a new one will be created.
Now, before you delete the content or fgdb, it may be wise to ask yourself why there is 30 GB of data inside your file geodatabase. When you start geoprocessing or generating results, it is good to create a file geodatabase in a project folder and store the results there with understandable names. You may have MXD's referencing the data in the default file geodatabase. So be careful with what you delete.
Are you using a lot of raster map calculations? Did you look at the content of the file geodatabase?
XanderBakker
AndySmith
Yes, you can treat this like any other geodatabase, it is just one created by the system and used as a default output if you have not specified anywhere else: ArcGIS Help (10.2, 10.2.1, and 10.2.2)
ayllaBAK
Thanx guys,
I see now when I load data into ArcMap...It was very quick and helpful replay.
Regards
XanderBakker
Hi aylla BAK
If it answered your question, could you mark it as such?
Thanks, Xander
AndrewAckerman
I have a project file in the default geodatabase that is very slow to load and will not show in layout view. My other mxds don't behave like this. I have not done any geoprocessing on it. Any tips?
AndrewAckerman
I figured out what was bogging things down. The basemap service.
ayllaBAK
Sorry for not replying to you. I was on maternity leave and did not check my messages .
