Calculate Direction/Angle of Polyline Feature Class Relative to North
3880
07-24-2012 04:35 PM
DarrochKaye
I am working with some cyclone data and I have plotted various tracks from a number of events. I would like to know the angle/direction of each segment of the line and I am unsure the best way to do this. Due to the nature of the data, it is imperative the angle must be in degrees relative to north, i.e. north = zero degrees.
I found this code below on another thread but it seems to be giving me the wrong results, e.g. a line which should have an angle of 180 degrees is calculated as 90 degrees, and another which should be around 60 degrees is 209 degrees - as you can see the error isn't consistent therefore I doubt it is the 180 variable as displayed in the code:
180 + math.atan2((!Shape.lastpoint.Y! - !Shape.firstpoint.Y!),(!Shape.lastpoint.X! - !Shape.firstpoint.X!)) * (180 / math.pi)
I am a Python novice (attending ESRI training course soon) but I do have XML and HTML code experience, so any help would be greatly appreciated.
DK
Pierre-LucBoivin
You can try this formula :
It's works great for me
def NorthAzimuth(Pline):
 degBearing = math.degrees(math.atan2((Pline.lastPoint.X - Pline.firstPoint.X),(Pline.lastPoint.Y - Pline.firstPoint.Y)))
 if (degBearing < 0) :      degBearing += 360.0
 return degBearing
DarrochKaye
 return degBearing
Thanks for the reply. Unfortunately when I paste this into the Field Calculator I get a generic error prompt: "There was a failure during geoprocessing, check the Geoprocessing Results window for details." But there is no record of this task in the results pane.
Thanks for your help.
DK
JayHalligan
Parser:
Python
Expression:
GetAzimuthPolyline(!Shape!)
def GetAzimuthPolyline(shape):
 degBearing = (math.degrees(math.atan2((shape.lastPoint.X - shape.firstPoint.X),(shape.lastPoint.Y - shape.firstPoint.Y))))+90
 return degBearing
This will return all + degrees with 0 degrees starting from the North rotating clockwise
